Browse Forums Building A New House Re: :(Slab set back too far back, no backyard, slight land s 12Aug 27, 2012 8:14 am www.tinas-cakery.com Building a Monte Carlo with Fowler Homes. Our Build Thread --> https://forum.homeone.com.au/viewtopic.php?f=31&t=49218 Re: :(Slab set back too far back, no backyard, slight land s 13Aug 27, 2012 9:15 am Build Thread: viewtopic.php?f=31&t=57639 Re: :(Slab set back too far back, no backyard, slight land s 14Aug 27, 2012 11:33 am Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: :(Slab set back too far back, no backyard, slight land s 15Aug 27, 2012 11:35 am Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: :(Slab set back too far back, no backyard, slight land s 18Jul 07, 2013 1:47 am bradster181 Looks like that is the only reasonable choice you have BIGZ. Use your front yard later on Naw thank you I agree! I posted this awhile back and this is definitely what Im doing now and it works perfectly Re: :(Slab set back too far back, no backyard, slight land s 19Jul 07, 2013 10:28 am In that case where are the pictures of the progress to feed the picture piggies on homeone.... Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24987 The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5747 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2152 |
