Browse Forums Building A New House Re: Porter Davis homes 7421Jun 15, 2013 4:02 pm Building the Ascot 35 with Carlisle Homes in Pasadena Estate, Clyde VIC My build thread: viewtopic.php?f=31&t=59776 Re: Porter Davis homes 7424Jun 15, 2013 6:51 pm Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ Re: Porter Davis homes 7425Jun 15, 2013 8:04 pm tai27 madhouse1 Hi Tai, Our niches are definitely functional, nothing slides off them, (except the soap sometimes,) I checked with the displays too and ours have about the same slope as the displays do. In fact its only just noticeable that theres any slope at all. That they are saying they're purely decorative is a lazy excuse for poor workmanship. And that your SS seems to be trying to get away with not fixing it is unbelievable. Those niches (when done properly) are fantastic!! As for that bath tap issue OMG, common sense isn't that common in the plumbing world?? Good luck and don't accept their ****** and excuses, that's really just not good enough. Will definitely have this looked into though, I believe it is a lazy excuse for poor workmanship as well. He isn't actually fixing it but has come up with a "solution". Spoke to him again yesterday and bought up the shower niche slop issue again. Unfortunately there's nothing he can do, as it is purely meant to be a "feature". He said ripping it out will result in damaging the waterproofing and having to pull the entire shower and tiles apart. He spoke to the building manager and apparently they believe it is fine as well and that there's nothing wrong with it as there is "no requirement for how much slope there is". I don't understand, these niche's are demonstrated throughout your display homes as niche's for holding shower products etc, and everyone on here seems to believe that his excuse to get away with this is just absolutely unacceptable and frustrating. SOLUTION: He said he had a similar issue happen to him before and that the result in fixing it was putting a glass shelve on the bottom with a 10mm gap at the back (apparently client was happy with this and end result actually looks "good" and doesn't look like an "add on") OK - If you're going to put a glass bit there then I might as well not have included these niches in my contract and bought glass shelves and installed them myself instead!! Hi Tai27, Your situation has been escalated to management. Someone will be back in touch with you on Monday. Regards, Helen Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 7426Jun 16, 2013 12:42 am tai27 He said ripping it out will result in damaging the waterproofing and having to pull the entire shower and tiles apart. He spoke to the building manager and apparently they believe it is fine as well and that there's nothing wrong with it as there is "no requirement for how much slope there is". SOLUTION: He said he had a similar issue happen to him before and that the result in fixing it was putting a glass shelve on the bottom with a 10mm gap at the back (apparently client was happy with this and end result actually looks "good" and doesn't look like an "add on") I wouldn't accept it at all... not your problem if they have to replace everything due to the tradesperson being completely incompetent... For a PD MANAGER to turn around and say that everything is fine and give some stupid excuse of "no requirement for how much slope there is" ... .that is just plain silly ... The glass slab ... even if it was tempered glass would allow so much water, crap and mould under it that you could never clean it! Imagine the stench coming from under that glass slab after a year of constant use of the shower! Re: Porter Davis homes 7427Jun 16, 2013 3:01 pm seashoremontague21 Using oh we have to re water proof is poor form our tiles where laid wrong 2 phone calls later they we ripped down and room replastered and water proofed all in a week I believe so dont take the fix. Teach them do it right first time. Hope you werent insulted with a $1000 to "keep it as is because noone does it that way anymore" andthat was for 3 wet areas Ah yes, I was reading your blog a few days ago and saw this issue with yours! No not yet but after hearing what has also happened with you I wouldn't be surprised. With yours though they'd definitely be more lenient compared to ours considering with ours "there's no requirement for how much slope there is" hrmm. Re: Porter Davis homes 7428Jun 16, 2013 3:08 pm madhouse1 Oh it just gets worse. That really isn't an acceptable solution in my opinion anyway. Can you imagine the mould and 'gunk' you'd end up with around that glass shelf. I'd be asking for it to be done properly, even if that means ripping it all apart and re waterproofing. Niches that are useless are really no good for anything and would be more frustrating than not having them at all. jnkbids ld allow so much water, crap and mould under it that you could never clean it! Imagine the stench coming from under that glass slab after a year of constant use of the shower! Thanks both for making me realise what issues could be arisen if they were to put the glass there. Looks like I'm going to have to fight this then. Hopefully someone from the PD management team get back to me asap. jnkbids your build is looking great by the way! I'm loving your blog. Just by looking at your photos of your niche as well and you couldn't even tell there was any issue with the slope of your niche (but then again it depends from the again it was taken I guess) Caulking was also done on Friday.. The slope continues.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Porter Davis homes 7429Jun 16, 2013 4:20 pm hi havnt been on for a while but now we finally have internet! just updated blog for those intrested Re: Porter Davis homes 7430Jun 16, 2013 4:59 pm ma2531 hi havnt been on for a while but now we finally have internet! just updated blog for those intrested Hi Ma2531, Welcome back to the real world now that you have the internet I can see you've been busy - your place looks amazing! I've also noted on the forum that others have driven by and admired it as well. I've sent your link onto the guys who worked on it as I'm sure they'll be interested to see how it looks furnished and landscaped. Thanks for sharing and I hope you spend many happy years in your new home. Cheers, Helen Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Re: Porter Davis homes 7431Jun 16, 2013 5:37 pm We're having PCI on Tuesday! Fingers crossed all goes well. Anybody got any tips for us? We have very little idea what to expect to be honest! Our independent inspector will be meeting us there half an hour before the inspection to talk things over though so that's reassuring. Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ Re: Porter Davis homes 7432Jun 16, 2013 5:54 pm ma2531 hi havnt been on for a while but now we finally have internet! just updated blog for those intrested Looks gorgeous!!! Re: Porter Davis homes 7433Jun 16, 2013 6:39 pm seashoremontague21 We're having PCI on Tuesday! Fingers crossed all goes well. Anybody got any tips for us? We have very little idea what to expect to be honest! Our independent inspector will be meeting us there half an hour before the inspection to talk things over though so that's reassuring. Exciting stuff, all the best on the day! Who is your independent inspector if you don't mind me asking? Our PCI is on the 27th of this month. Everyone seems to be having their independent come out on the day of PCI but our BS said to get them to come out a day or two after Porter Davis' own inspectors (BSS Inspectors) have come out? Does this sound right? Never really done this before so would like to know how this process usually works. Re: Porter Davis homes 7434Jun 16, 2013 10:08 pm Can someone pls quote facade prices for lifestyle double storey range? i noticed on h1 lot of people are upgrading bricks. is this due to quality difference or just for look? what kind of staircase are standard and what upgrade options are available? thanks. Re: Porter Davis homes 7435Jun 16, 2013 10:31 pm tai27 seashoremontague21 We're having PCI on Tuesday! Fingers crossed all goes well. Anybody got any tips for us? We have very little idea what to expect to be honest! Our independent inspector will be meeting us there half an hour before the inspection to talk things over though so that's reassuring. Exciting stuff, all the best on the day! Who is your independent inspector if you don't mind me asking? Our PCI is on the 27th of this month. Everyone seems to be having their independent come out on the day of PCI but our BS said to get them to come out a day or two after Porter Davis' own inspectors (BSS Inspectors) have come out? Does this sound right? Never really done this before so would like to know how this process usually works. Way I see it get you, independent inspector, site super and who ever pd might get all go in on the day sit down at the end and make one list Re: Porter Davis homes 7436Jun 17, 2013 7:22 pm Just an update in regards to our niches issue - BS called and management had gotten onto him in regards to my niche issue (Thanks Helen!) The one in the Ensuite would be fixed (not sure how the slop will be now though) but the one in the main bathroom will not as both the BS and the management team believe there isn't an issue with it and meets the "requirements"
Have a look: http://www.youtube.com/watch?v=IWRxFWi- ... e=youtu.be Re: Porter Davis homes 7437Jun 17, 2013 7:35 pm tai27 Just an update in regards to our niches issue, BS called and said the one in the Ensuite would be fixed (not sure how the slop will be now) but the one in the main bathroom is fine. Apparently management believe it is fine as well. Have a look: http://www.youtube.com/watch?v=IWRxFWi- ... e=youtu.be [youtube]<iframe width="640" height="360" src="http://www.youtube.com/embed/IWRxFWi-p2c" frameborder="0" allowfullscreen></iframe>[/youtube] <iframe width="640" height="360" src="https://www.youtube.com/embed/IWRxFWi-p2c" frameborder="0" allowfullscreen></iframe> I see the difference in slopes between yours and the display home. Not good enough. I hope you send your BC this vid? How can they think there is nothing wrong with that? It is not functional. Your video isn't a good advertisement for PD, Pantene or Jif!! Re: Porter Davis homes 7439Jun 17, 2013 9:52 pm Hi guys sorry for anyone who has heard this too many times. When are we getting 24/7 back? I am having extreme issues with non communication from anyone apart from Helen at PD. Does anybody know? If I am lucky enough that my BC picks up the phone all I get is "I will find out and get back to you" which has never happened yet. I get no response to emails or messages. Considering what we are paying for this house, I do not think it is too much to ask to let us know what is going on! Re: Porter Davis homes 7440Jun 17, 2013 9:55 pm tai27 Just an update in regards to our niches issue - BS called and management had gotten onto him in regards to my niche issue (Thanks Helen!) The one in the Ensuite would be fixed (not sure how the slop will be now though) but the one in the main bathroom will not as both the BS and the management team believe there isn't an issue with it and meets the "requirements" Have a look: http://www.youtube.com/watch?v=IWRxFWi- ... e=youtu.be You would have sworn this was comedy show how hard my partner and i laughed Did you actually turn the water on in the display home I loved the shots looking at the ground and back up in the display home like...... ................................ yup its still on the ledge Decorate your home. It gives the illusion that your life is more interesting than it really is. MY BUILD THREAD https://forum.homeone.com.au/viewtopic.php?f=31&t=65479&p=1035832#p1035832 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12336 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74701 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105553 |
