Browse Forums Landscape & Garden Design Re: What to plant in shallow/narrow gardenbed facing west ? 2Jun 15, 2013 7:39 pm Look at succulants, good ones are Aeonium arboreum & Cotyledon orbiculata... Easy to control, but at the end of the day you will need to prune back whatever is growing to satisfy the horse s**t that the termite guys spins.. Re: What to plant in shallow/narrow gardenbed facing west ? 4Jun 19, 2013 11:08 am I see you have camleias there in the opposite bed. To try and tie into these somewhat id suggest some small shrubs that will suit the brief such as - raphiolepsis, nandina, buxus, osmanthus. or if you want a groundcover that can be easily pulled back to assess your inspection points look at trachelospermum asiaticum (groundcover star jasmine) all the above are very tough. Re: What to plant in shallow/narrow gardenbed facing west ? 5Jun 19, 2013 3:27 pm OG, I can't dig out too much of the 'rubbish' you can see there currently - it's quite shallow before hitting sandstone, etc.. and I can't add too much 'good' soil in order to keep the weep holes clear. Therefore the bed will not be very deep I like your recommendations but do you think they are tough enough to grow in such a shallow bed ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: What to plant in shallow/narrow gardenbed facing west ? 7Jun 20, 2013 2:54 pm Giant liriopes would work. Or other ornamental grasses Re: What to plant in shallow/narrow gardenbed facing west ? 12Jun 22, 2013 7:55 pm I think the pots are a great suggestion. Then I would fill the garden bed with blue metal, we used it as a cheap solution for the dead side of our house and it looks fine. Regards, Grumbles Re: What to plant in shallow/narrow gardenbed facing west ? 13Jun 22, 2013 11:24 pm Western sun, brickwalls and pots = heaps of water and plants with scorched leaves... Re: What to plant in shallow/narrow gardenbed facing west ? 15Jun 24, 2013 6:08 pm On the western side of our shop front we have 3 dessert roses in 3 black pots with white stones as much with some succulent things growing in between the white rocks. They all seem to pump along ok with once a week watering. Re: What to plant in shallow/narrow gardenbed facing west ? 16Jul 04, 2013 9:50 am Hi all, thanks so very much for your ideas. I am still working on them............. Still not sure what I want to do, but have to make up my mind before the next termite treatment in August. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: What to plant in shallow/narrow gardenbed facing west ? 17Jul 11, 2013 10:22 pm After thinking about all of your suggestions, I've decided to plant dwarf Lomandras (plants in front) : I've planned to keep the narrow bed simple, while allowing easy access to termite inspection points; also keeping the vents clear. Again, thank you all Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4800 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 20101 Thanks again for this information. If you do hear anything different, would be great to know 4 8329 |
