Browse Forums Landscape & Garden Design Re: Tools for planning a big landscaping job 4Jun 13, 2013 7:45 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Tools for planning a big landscaping job 7Jun 14, 2013 6:54 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Tools for planning a big landscaping job 8Jun 14, 2013 1:14 pm I will chip in here and agree with everything Cherub is saying. I have only started in the design side of landscaping in the last 6 months and i haven't found the need for autocad yet, sketchup has all the functionality required atm. The thing is, even if you have audocad it is not going to get you a better design, it's only a drawing tool. There is not much that you can do in autocad that you can't do by hand drawing (residential level). Its just slower, and since time isn't an issue in your case why bother spending months getting to know autocad when you could be studying actual garden design principles? Autocad is a professional tool to create accurate drawings fast and is made for designers that create plans day in day out.. Not one off jobs. As Cherub pointed out sketchup is more than capable of handling your site and has a way smaller learning curve. Even gardencad would work in your situation. The bonus with sketchup is you can pop up a 3d model of your site so easily and this is very very helpful in understanding your levels and contours. You would be surprised by how many landscape designers/Architects still create hand drawn concepts before drafting them in CAD software.. A lot don't even use cad programs at all:). If i was you i would get a feature survey done by a surveyor and use a dumpy level for construction.. Then do some study on garden design with the time you saved not learning autocad.. Re: Tools for planning a big landscaping job 9Jun 14, 2013 5:07 pm Wow, Almost and Acre to landscape. What a fantastic project! Good luck - please post pics. Re: Tools for planning a big landscaping job 10Jun 14, 2013 6:08 pm Ok, perhaps I need to take 1 or 2 steps back. I think I better get in touch with the council and find out exactly what their requirements are. Common sense may not be sufficient I though that having a really good idea of the lay of the land prior to shelling out for experts would make decision making easier, but if they are going to demand a formal surveyors report anyway then I may as well get an expert in to do the job. Thanks for the wisdom regarding software requirements. I'll have a play with sketchup. KnockItDown Wow, Almost and Acre to landscape. What a fantastic project! Good luck - please post pics. Don't hold your breath. It's going to take a while Re: Tools for planning a big landscaping job 11Jun 14, 2013 6:39 pm Didn't say you will need a surveyor, just in suburbia due to close proximity of boundary's we have to when carrying out any works which impact on others. If your not doing any works on the boundary maybe not needed, talk with your council Landscape Design & Construction http://cherub.squarespace.com/ Re: Tools for planning a big landscaping job 12Jun 14, 2013 9:59 pm May I also add to this, whilst not being from a landscaping background, I am from a surveying background. If you have no previous experience in the field and don't know anyone that does, perhaps some time learning the basics and concepts of surveying and instrument handling may be a start, it looks very simple from the outside but i assure you it isn't. Simply setting up a theodolite/total station correctly over a given mark can be frustrating for a beginner. You may also find out which instrument and other equipment is more appropriate for you. Along with this comes the actual measurement phase, where the readings should be taken to ensure the contours are an accurate representation of what's on the ground. Things like breaks lines, top of banks, bottom of banks are critical when it comes to contour plans and without an understanding of these you will just end up with a page full of measurements. Similarly Autocad and other professional software packages are also quite in depth and can be very daunting if you don't know where to start. I am now out of the profession and haven't seen Autocad in quite a few years and wouldn't be sure if i could still use it immediately. If it were me, I would get a quote for a detail/contour survey. If the site is fairly open it is pretty straight forward and quick job, meaning not too expensive. They can also provide you with a Australian Height Datum (AHD) mark for levels and other reference marks for you to use for future setting out purposes. A detail plan will also give you some idea where about your features and structures are in relation to the boundaries. Which could be quite important depending on how close you are planning your retaining walls etc to the boundaries. As already stated they can also give you a digital version to import into your own software. Hopefully this helps somewhat and doesn't turn you off too much. And here i was trying not to write too much and just cover some of the pertinent points....... Re: Tools for planning a big landscaping job 13Aug 19, 2013 3:35 pm KeeperSD ...Helpful info... Thanks for that comprehensive post. I took your advice re:getting a quote and was a bit shocked at the $2500+ price tag for a suburban 800sq m block (investment property interstate that I was having similar ideas about). I didn't get one for this place as it is a much bigger job. Not that I disrespect the level of knowledge and skill involved, especially now that I have acquired a dumpy level and had a bit of a play! More that I don't need to be spending that kind of cash at the moment if I can avoid it. Anyway I now have a dumpy level and have been inputting the points into Sketchup. The pictures are almost making sense! But I need to work on my accuracy. I'll start another thread to discuss that tho. No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4999 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7162 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10521 |
