Browse Forums Flooring & Floor Covering Re: Vinyl planks? (timber look floors) 21Oct 09, 2012 9:41 pm Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Vinyl planks? (timber look floors) 25Oct 10, 2012 5:46 pm Jem's Custom build - viewtopic.php?f=31&t=58630 Re: Vinyl planks? (timber look floors) 27Oct 10, 2012 7:24 pm https://forum.homeone.com.au/viewtopic.php?f=31&t=43937&start=0 Bought a block in Golden Grove - Jan 2011 Finally finished our design, Mar 2012, *yay* Signed with ADH council consent June 12 Re: Vinyl planks? (timber look floors) 30Oct 22, 2012 2:41 pm 23 Aug 2011: Land settlement 14 Sep 2011: Block levelled 20 Oct 2011: Slab 3 Nov 2011: Frame 10 Feb 2012: Handover http://s1098.photobucket.com/albums/g372/Dazzab6/ Re: Vinyl planks? (timber look floors) 31Apr 21, 2013 9:59 am Build Threadhttps://forum.homeone.com.au/viewtopic.php?f=31&t=68156 Lendlease/Elderton Cntract:31-01-13 Settled:1-10-13 DA: 10-10-13 CC: 28-11-13 SC: 3-4-14 Re: Vinyl planks? (timber look floors) 38Jun 05, 2013 4:32 pm The ones here were laid straight over the concrete slab. They are quite thick. The slab needs to be smooth without pits or raised bits otherwise you will get wear spots. Re: Vinyl planks? (timber look floors) 39Jun 05, 2013 5:11 pm Ours were also laid straight over the concrete. The installers made sure the finish was perfect before laying & put a trim across bathroom/laundry entrances so that difference in heights was not an issue. Would not recommend DIY. Building Stroud 30 in Lake Macquarie Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8570 Interested in getting either the Polytec Boston Oak or Palace Peak for kitchen cabinets. Looking at the Boston Oak ones, it appears that the colour varies significantly… 0 11386 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16186 |
