Browse Forums DIY, Home Maintenance & Repair Re: Unable to remove cap from top of Dorf tap 2Jun 04, 2013 6:53 pm some taps have a nut(needs a special tool)underneath the handle Re: Unable to remove cap from top of Dorf tap 4Jun 05, 2013 3:11 pm Quote: Any idea where I can buy the special tool? Any plumbers suppliers but if its extra tight you will find the spanner lugs straighten out or break off Quote: I wonder if a pair of circlip pliers would work? eg .... Would probably be a whole lot stronger. When you replace the nut add a smear of grease to make it easier next time Arfur How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6058 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11974 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7169 |
