Browse Forums Bathrooms and Laundry Re: White growth coming through grout in bathroom 2Jun 04, 2013 1:04 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: White growth coming through grout in bathroom 3Jun 04, 2013 1:19 pm HomeAngels If it's growing I'd definitely say its mould. You don't have to have a leak to get mould. Where is the mould growing? Is it on a part of the floor that often gets wet/damp? Interesting, figured it had to be related to water under the tiles. It's all in areas that never get wet unless mopped which is bugger all moisture anyway (plus windows are usually open or fan on). The shower base just has the darker grout which I assumed was due to be constantly exposed to water. There aren't any white growths/marks in that area at all. Re: White growth coming through grout in bathroom 4Jun 04, 2013 1:23 pm Hmmm Mould needs moisture/dampness to thrive so if it's not a spot that regularly gets wet then you may have a leak I would have no idea how to even start looking to see if there is a leak. Are there water marks on the ceiling below? Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: White growth coming through grout in bathroom 5Jun 04, 2013 1:28 pm Nope, can't find anything anywhere else which is why I asked if it was possible for water to travel through the grout over time. If it was a serious amount of water, I'd have found it somewhere else for sure. Re: White growth coming through grout in bathroom 6Jun 04, 2013 1:30 pm Grout is porous so I suppose in theory it is possible. Ive never heard of it though. I hope someone here can be better help than I was Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38438 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5447 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 |
