Browse Forums Home Theatre & Automation Re: Projector for family room? 2May 25, 2013 10:47 pm Hi Tweety, Never trust a salesperson What they are saying is true to a degree though. It depends a lot on the model. The Epson TW9100 is almost bright enough to be used in full daylight but depending on how the light comes to the screen (and the screen type used) it will look washed out. You don't need a "bat cave" but it is handy to be able to control the light. Based on the room dimensions you are looking at a good screen size (90" to 100") and depending on your budget you may find the large screen value outweighs the LED /LCD argument. ie. Size matters Have you had the opportunity to have the products you are looking at demonstrated in a light environment? Did you have a budget to work to (PM me if you prefer) ? Cheers, Matt Re: Projector for family room? 3May 25, 2013 11:28 pm Hi Matt, Thanks for your reply, looking washed out is what i was worried about. the projector is a Mitsubishi HC7900, the brochure that I have doesn't specify the type of screen it just says 2.7m. As for the price, it is for a complete home theatre system, fully installed, the components are : Mitsubishi HC7900 projector 2.7 m screen Yamaha Aventage 720 receiver Yamaha 473 bluray player Yamaha NS555 surround sound 5.1 channel speaker package Yamaha subwoofer Set to box Cables and brackets 4 3d glasses For $6990 What is your opinion on the projector and the package? Unfortunately the setup in the store was in a dark room, although they did turn the lights on I am not sure it was a true reflection of how it would look with direct light. Thanks for your help Tweety Re: Projector for family room? 4May 26, 2013 9:25 am It all depends on the lumens. how bright is the projector.We bought a acer projector(cheap one) and it had 3000 lumens. We used in a huge room with lots of light and some outside light. It was very very bright. Now having direct sunlight hit the screen well don't expect too much. The same goes for any plasma or lcd screen. You need to see how the room handles sunlight during the day and see if any direct sunlight hits your screen during your viewing times. I will be doing something similar when i get to build my house in a few months or so... Good luck Mixo Re: Projector for family room? 5May 26, 2013 5:35 pm tweety Hi Matt, Thanks for your reply, looking washed out is what i was worried about. the projector is a Mitsubishi HC7900, the brochure that I have doesn't specify the type of screen it just says 2.7m. As for the price, it is for a complete home theatre system, fully installed, the components are : I have a simple answer to that question: http://www.thecableconnection.com.au/Fu ... -here.html If you are in Melbourne pop down to our store and I will show you the differences between models and how they work with light. Cheers, Matt Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 6114 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 5351 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 14456 |
