Browse Forums Bathrooms and Laundry Re: window coverings in bathroom/toilet/laundry?? 2May 21, 2013 1:21 pm I've never bothered with window coverings in bathrooms when the glass is obscured/rippled. I figure you don't need to block the light in those rooms and we've never had privacy issues. But if there was an obvious privacy concern (like even obscured glass in open view of neighbours) then I guess it would depend on size/position of windows. For small windows in places like laundries I like roman blinds. Or perhaps shutters when it's either side of ensuite sinks (more of a feature). I'd probably just wait and decide after I moved in! Build thread: viewtopic.php?f=31&t=65085 Re: window coverings in bathroom/toilet/laundry?? 3May 22, 2013 2:34 am Although we do have obscured glass, we have shutters in the ensuites, powder and bathrooms and a roller blind in the laundry (not obscured) as its a sliding door. Personally, unless you have gorgeous timber windows to look at, I prefer to have some form of window dressing. I find it also helps to block out the light and heat in summer or on west facing windows and keep the heat in in winter. Re: window coverings in bathroom/toilet/laundry?? 4May 24, 2013 1:57 pm Ours are clear - ie no blinds etc. But - the shower ones are long and high. The initial shock we got - after not raising our needs with the builder - was to find we had clear glass in the ensuite toilet .... We have "cathederal" (I think its called) in all of the bathroom/toilet windows. Re: window coverings in bathroom/toilet/laundry?? 5May 28, 2013 7:53 am Is it possible to get window films in Australia, perhaps via e-bay if no where else? You can install these yourself with a squeegee and a spray bottle. This firm is very popular in the US: http://www.lighteffects.com/ You can "obscure" your windows with these, and they are easily removed if you change your mind. Also, a lot less expensive than most window coverings! Ahhhh... google to the rescue: http://www.transformitimages.com.au/onl ... ative-film Chris On the threshold of retirement... and trying to check my assumptions at the door Re: window coverings in bathroom/toilet/laundry?? 6May 28, 2013 5:08 pm ChrisE Is it possible to get window films in Australia, perhaps via e-bay if no where else? You can install these yourself with a squeegee and a spray bottle. This firm is very popular in the US: http://www.lighteffects.com/ You can "obscure" your windows with these, and they are easily removed if you change your mind. Also, a lot less expensive than most window coverings! Ahhhh... google to the rescue: http://www.transformitimages.com.au/onl ... ative-film We used Frosted film from http://www.tintplus.com.au/ (http://www.tintplus.com.au/decorarive-frosted-film-for-the-home/decorative-frosted-film-residential) to cover all our windows that face out to the common area of our townhouse. Turned out really well, I measured the windows I wanted covered, submitted the order on-line and an installer came out and installed it all - easy! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Hi there I'm looking for a independent company for a expert report on my blinds ,sheers & plantation shutters I'm in Melbourne 0 9225 Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added… 0 14112 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11252 |
