Browse Forums Building A New House Re: Slab to Brick Work 5May 14, 2013 8:24 am Kenny & Kayla - Adelaide Follow our build on Instagram First build 2013 - Finished and sold Second build 2018 - Underway Re: Slab to Brick Work 10May 17, 2013 1:28 pm Novice - in WA we don't have frames all our walls are brick Hope your brickies start ASAP Re: Slab to Brick Work 12May 17, 2013 7:11 pm Exterior walls are double brick and internal walls single brick Re: Slab to Brick Work 14May 18, 2013 12:09 am novice8 Sorry but comments like these still crack me up. We are like another country over here in WA. It's like a theme park in Paris. Ridiculously hot in summer , too cold in winter, unbearably expensive all the time, and all the park staff are rude and uncaring There is a reason we are so far away, sometimes I wonder if it is for our own good. Keep up the good work Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1064 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3497 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10083 |
