Browse Forums Building A New House Re: Level 1 construction Shock!!! 9Sep 08, 2008 10:26 am We are building in a site that I think will be Level 3 - $15k worth of extras including toughened glass After 4 years - we're in! Re: Level 1 construction Shock!!! 11Sep 08, 2008 12:00 pm Hi Raz, just saw this thread and thought I would re-iterate your concern re cost of your gutter guards. We have just been quoted $1,502 (incl builders margin) for our metal mesh gutter protection system (also required to comply with HAPZ regulations). So, unless the valley guards are very expensive (we didn't require these) I would be asking for another quote. 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: Level 1 construction Shock!!! 12Sep 08, 2008 5:33 pm Either someone's having a lend of you or you've forgotten to put in the decimal places. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Level 1 construction Shock!!! 13Sep 08, 2008 10:59 pm Rachelle I guess the standard gutters were made from some other material? Yeah! a Precious metal perhaps!! I would so like to keep a calm equilibrium during this build process but really what do the builders think! Raz If you think you can, you can. Re: Level 1 construction Shock!!! 14Sep 08, 2008 11:03 pm stonecutter1309 We are building in a site that I think will be Level 3 - $15k worth of extras including toughened glass Hi stonecutter1309, The grand total for mine comes to $12,330. Prior to sigining the tender I had asked about an estimate of costs and they said 3000-5000. How is it that builders prices can increase so dramaticlly. Were you prepared for these prices ? prior to tender? Raz If you think you can, you can. Re: Level 1 construction Shock!!! 15Sep 08, 2008 11:05 pm enigma_brennan Hi Raz, just saw this thread and thought I would re-iterate your concern re cost of your gutter guards. We have just been quoted $1,502 (incl builders margin) for our metal mesh gutter protection system (also required to comply with HAPZ regulations). So, unless the valley guards are very expensive (we didn't require these) I would be asking for another quote. HI Paul, What is the size of your home? Defitnitely going to ask for another quote!! Also what is HAPZ regulations? is this bushfire regulations? Thanks for your reply and advice Raz If you think you can, you can. Re: Level 1 construction Shock!!! 16Sep 08, 2008 11:07 pm ausdesign Either someone's having a lend of you or you've forgotten to put in the decimal places. Hello ausdesign, Oh! I wish it was the case of mistaken decimal places. I might put the question to my buidler as you have !! Like to see their faces! I am so unprepared for this.. it all adds up and completely blows your budget Raz If you think you can, you can. Re: Level 1 construction Shock!!! 17Sep 09, 2008 1:43 am Raz, our house is a little smaller than most at 18sq so you might expect your quote to be a little higher but not three times as much - unless your house is 54sq?
Yes, HAPZ regulations is the term our builder used for our bushfire requirements - not sure what level we are - just that we were required to have a metal gutter guard system but not required to have sarking. Good Luck. 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: Level 1 construction Shock!!! 18Sep 09, 2008 7:35 am Raz The grand total for mine comes to $12,330. Prior to sigining the tender I had asked about an estimate of costs and they said 3000-5000. How is it that builders prices can increase so dramaticlly. Were you prepared for these prices ? prior to tender? The builder was going to put us down for Level 1 protection but by my calculations I think we may be Level 3 - they didn't give us an estimate before tender because there were so many things to cost - but we knew it would be a bit. We were happy to spend a bit more money on fire protection as I've lived in a heavy bushfire area. After 4 years - we're in! isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17702 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6690 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47050 |
