Browse Forums Building A New House Re: Builders margin 4Apr 30, 2013 9:33 pm newey I may be thinking wrong but my builder is charging 20% for the total bill of works and not just for the sum over the provisional amount. Is this normal? It seems they are getting 2 bites of the cherry. eg storm drainage 3k provisional Invoice 3.5k builders margin of 20% =700 I would have thought in the provisional cost would have already have had builders margin. Ahhh trap for first timers What type of contract are you on? the Invoice that was 3.5k is that actual invoice from the company that completed the works, do you get to see the invoice? If the invoice is 3.5k, then you'd expect to pay 20% maring on the 3.5k. Re: Builders margin 5May 01, 2013 4:18 am I think your builder is right. The provisional sum is more or less an indicator of how much things might be which usually doesn't take builder's margin into consideration. In case it is less than the provisional amount, builder's margin will be the actual amount. Look at your bill from the electricity company. It should detail the charges. You will need to do some estimating and some calculations. Then charge the… 8 4307 Site works are just about to start on our build with Blueprint in Midvale. viewtopic.php?f=31&t=106894 2 4020 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12275 |
