Browse Forums Building A New House Re: Mirror or vinyl sliding wardrobe doors? 2Apr 11, 2013 12:47 pm Build #2 Builder: In-Vogue Design: Custom 2 Storey Build #1 Builder: New Generation Homes Design: The Monterey My Build Thread: viewtopic.php?f=31&t=60453 Re: Mirror or vinyl sliding wardrobe doors? 11Apr 11, 2013 3:57 pm Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Mirror or vinyl sliding wardrobe doors? 15Apr 11, 2013 8:05 pm Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 Re: Mirror or vinyl sliding wardrobe doors? 16Apr 11, 2013 8:30 pm Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Mirror or vinyl sliding wardrobe doors? 17Apr 12, 2013 2:20 am Building in Myalup with Redink PCQ : Nov 2012 Prestart: 17 th March 2013 Builders Permit: Sept 2013 Completed build Aug 2014 viewtopic.php?f=31&t=67559 Re: Mirror or vinyl sliding wardrobe doors? 18Apr 12, 2013 4:39 am the white is very nice we are also using the white in bed 4 thought it would go with the beachy theme we have going on there Re: Mirror or vinyl sliding wardrobe doors? 19Apr 16, 2013 12:05 pm If you're planning on changing from vinyl inserts to mirror inserts, you should be able to take the frames apart and put the mirror inserts in relatively easily. You will just need glazing bead (most glass manufacturers should be able to supply this). In my opinion, it's also important to buy mirrors with safety (vinyl) backing. Re: Mirror or vinyl sliding wardrobe doors? 20Apr 16, 2013 9:35 pm I used to work at a wardrobe-s/screen mfr and mirrors weren't too much more than vinyl. The frames do come apart and the beading can be reused. But after the hassles of having a mirror cut to size, transporting it and taking the door apart and putting it all back together (using a rubber mallet)... you're only really saving on the aluminium frame cost anyway. Depends on how much you value your free time There's always the option of dropping the doors off at the factory & have them change it over for you, is only a 10min job. Hi all, I'm hoping someone might be able to point me in the right direction. We were hoping to have our dining and lounge room open out onto our alfresco using 3 doors of… 0 18413 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 7750 1 3810 |
