Browse Forums Building A New House 1 Mar 27, 2013 3:01 pm Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Wasington 29 from Wisdom Home 2Mar 28, 2013 8:58 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Wasington 29 from Wisdom Home 3Mar 28, 2013 8:36 pm We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Wasington 29 from Wisdom Home 5Apr 03, 2013 10:33 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Wasington 29 from Wisdom Home 6Apr 03, 2013 10:38 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 7Apr 03, 2013 10:54 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 8Apr 03, 2013 11:04 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 9Apr 03, 2013 11:57 am We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Washington 29 from Wisdom Home 10Apr 03, 2013 1:22 pm Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 11Apr 03, 2013 5:40 pm We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Washington 29 from Wisdom Home 12Apr 04, 2013 9:39 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 13Apr 04, 2013 12:52 pm We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Washington 29 from Wisdom Home 14Apr 05, 2013 10:18 am Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Washington 29 from Wisdom Home 15Apr 05, 2013 11:09 am Transformation I really like the timber handrail and zigzag, looks fantastic. Will try to see if i can come up with some money. I will stick with standard tiles and carpets. Is your front door is also upgraded to timber finish? I am pretty sure the timber door stained is standard, but just check with your salesperson in case these things have changed since I did my tender (18 months ago) I suggest you ask for everything you wish for in your tender so they can go away and price it for you for your home choice. Then you can just go through the tender list and take off what you can't afford to get to your final tender cost. We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Hi, guys! If you've built with Wisdom Homes, would you mind sharing images of your front facades once they're all rendered? I'm considering signing up with them for a wide… 0 15351 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19727 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75496 |
