Browse Forums Lighting + Lighting Design 1 Sep 15, 2008 8:22 pm We are doing our electrical plan ATM.
I run a business from our study in the current house, we have two desks and a credenza that I use as a work bench. In the new house, we will have a study of approx 4.3m by 3.5m with 2.7 ceilings,with a work top height of 750mm. I am considering having downlights over the desk areas as the light would be more focused. Currently, if I work at night I sit in my own shadow as the desk is against a wall. So, does anyone have downlights for task lighting in the study? If so, are you using 1 per desk area and what size/W are you using? Do you have a "standard central ceiling light" as well? Does it work well for you or would you change it for something else? I am thinking of getting a "bar type" of central light with say 4 spots on it, so that the light can be directed to the fax machine, printer, bookcases etc. in conjunction with the downlights. Otherwise we are considering a round fluro for the centre of the ceiling which is what we have now. All ideas/thoughts on this welcome. Cheers Joanne Re: Task Lighting in Study 2Sep 15, 2008 8:25 pm I would do the round fluro….and the down lights above your work desk. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Task Lighting in Study 3Sep 15, 2008 8:27 pm Hi, we currently have a central downlight in the study with two over the desk so not to be in shadow.
The desk is just under 2 meters. We are also getting the other side of the study fitted out and I have put in two downlights (cabinet makers reccomendation) over my desk which is only 1 meter wide. I would not go with any less. Paula Re: Task Lighting in Study 4Sep 15, 2008 9:04 pm In my current (crap) rental, because of limited space, my computer is under a bulkhead with a downlight overhead...... the lighting is perfect... so good in fact that we specifically set the lighting in the new house so that it will be like this . I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Task Lighting in Study 6Sep 19, 2008 8:01 pm Sallyho what does that mean?????
We have a 6 x 6 study. yes 6m by 6 m so we've gone with 2 lights. They are batten lights for the moment but will likely be replaced with oysters or one oyster and one set of spotlights after handover. I guess if we need more we'll add downlights later. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
