Browse Forums Lighting + Lighting Design Re: Low ceiling and pendant lights 2Aug 21, 2018 11:46 am I think a 1.4m ceiling would look odd regardless of the lights 4 6201 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13762 |
