Browse Forums Lighting + Lighting Design Re: Lighting recommendations in Sydney 4Aug 04, 2018 7:47 pm Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Lighting recommendations in Sydney 5Aug 05, 2018 9:26 am Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Lighting recommendations in Sydney 6Aug 05, 2018 9:29 am Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Lighting recommendations in Sydney 7Aug 05, 2018 10:01 am Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Lighting recommendations in Sydney 8Aug 05, 2018 11:10 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Lighting recommendations in Sydney 10Aug 05, 2018 4:24 pm Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Lighting recommendations in Sydney 12Sep 01, 2018 7:00 pm Huhness Space Furniture and Matt Blatt Thank you Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Lighting recommendations in Sydney 13Mar 15, 2019 5:52 pm ponting216350 I recommended Moon Light. Thank you Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7554 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28821 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8825 |
