Hi,
Do people normally go for the 70 or 90mm led downlights?
What is the standard
Thanks.
Browse Forums Lighting + Lighting Design Re: LED downlights cut out diameter. 3Jul 07, 2018 7:24 pm Generally you will find 70 mm is for fixed 90 mm is for adjustable Also depending on type of light _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10247 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5498 2 5503 |
