Browse Forums Lighting + Lighting Design 1 Mar 08, 2018 2:38 pm Please see attached photo. Try as I might I cant find how to access the bulb. I have tried unscrewing the screw at the base- no go as its still attached to the wall by two internal screws that I cant get to. The two internal screws cant be accessed as the glass panels prevent this. There are no other screws on the outside and the glass doesnt seem to slide out of the way. The black part appears to be one whole piece. If it was my place I would just replace it, but as not would like to change the bulb as we have no outoside light! Cheers everyone Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Changing a bulb outdoor light 2Mar 08, 2018 5:14 pm We had a cast light fitting like this, and the top lifted off after unscrewing the finial. Does the exposed screw allow you to drop the bottom out or is there a screw perhaps hidden in that top finial (bulgy bit) that allows that to lift off. I know you said it appear to be one piece, but light fitting companies generally aren’t in the business of testing your cognitive skills . Changing a bulb outdoor light 3Mar 08, 2018 8:14 pm Now that I look at it again, I see a rubber seal between the cast outer and the white mounting plate. Are you certain that when you undo the bottom screw the entire cast section (with glass) doesn’t pull away from the mounting plate, or even hinge up the top somewhere leaving the bulb easily accessible? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Changing a bulb outdoor light 4Jul 09, 2018 3:43 pm Have you figured this out? _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 9162 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 4177 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 3266 |
