Browse Forums Lighting + Lighting Design 1 Jan 06, 2018 7:51 pm We have one downlight that flashes rapidly for 1-2 minutes on initially being switched on. It's on it's own driver, no dimmer but on the same circuit as 3 other downlights plus a fan that has two globes in it. After the flashing it settles down and is fine. Any ideas? Is the driver on the way out? Re: Flashing LED Downlight 2Jan 06, 2018 10:40 pm Althom We have one downlight that flashes rapidly for 1-2 minutes on initially being switched on. It's on it's own driver, no dimmer but on the same circuit as 3 other downlights plus a fan that has two globes in it. After the flashing it settles down and is fine. Any ideas? Is the driver on the way out? This happened when an LED is connected to an existing halogen downlights. I have this issue in the pass and replaced the LED to a Phillips one and it works fine now. I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 11252 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6562 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10490 |
