Browse Forums Lighting + Lighting Design 1 Nov 27, 2017 7:32 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi I just received my electrical plan. I note the single hallway light does not line up with the row in the living area (refer to blue line). Would there be any reason why this is the case? Is it possible to move them across inline with the blue line. The second row would also need to move across. The required move is approximately 300mm. Thanks Re: Do downlights need to line up? 2Nov 27, 2017 8:53 pm I was told that when the day comes to installing the downlights that they would line it up. I didn’t trust them to do it correctly or do it the way I want the so I make sure it was lined up in our plans. You won’t be able to get everything to lined up but pick the ones that you want or can Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11957 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7144 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10333 |
