Browse Forums Lighting + Lighting Design Re: bathroom lights 4Sep 30, 2017 10:28 pm lenarufus arcadelt That’s the definition of overhead lighting, so probably not unless you always want to look like you have black eyes. What would you suggest? Maybe one over the shower area and wall lights on the either side of the mirror? If so, any suggestions? Thanks Yes, wall lights on either side of the mirror. How you then light the whole room is up to you. So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23022 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8370 |
