Browse Forums Lighting + Lighting Design Re: Dimmer switch for led lights 3Jul 26, 2017 5:18 pm Flickering when dimmed strongly suggests that your builder has installed non-dimmable LED lights, presumably to save costs. Dimmable LED lights are widely available, and I would've thought that they'd be the default by now, but there you go. It's easily rectifiable by replacing the cheap LED lights with proper dimmable ones. As a short-term workaround you should be able to just leave the dimmer switch on full brightness. Re: Dimmer switch for led lights 5Jul 29, 2017 9:26 am Two issues. The first is poor quality LED lights, which I'm sorry to say basically all builders use. $10 junk from China. Second issue is using a dimmer that is not specifically designed for LEDs. If they try and say "it's normal operation" they obviously have no idea what they are talking about, or are telling you fibs Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Dimmer switch for led lights 6Jul 30, 2017 3:56 pm 1960sModernistHome Two issues. The first is poor quality LED lights, which I'm sorry to say basically all builders use. $10 junk from China. Second issue is using a dimmer that is not specifically designed for LEDs. If they try and say "it's normal operation" they obviously have no idea what they are talking about, or are telling you fibs Thanks, I requested for details about the LED and dimmer from my builder. They said they use dimmable led and compatible dimer switch and If I want to remove the dimmer just in case, It will cost around $100. I am going with dimmer switch. I hope, It works fine. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1197 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23019 |
