Browse Forums Lighting + Lighting Design Re: Positioning of two pendants about island bench 3Jun 23, 2017 12:43 pm Depends. If evenly spaced, then one at 1m and the second at 2m, that leaves 1m at each end and 1m in between. However, that may not suit your aesthetic, so you could play with that a bit. Re: Positioning of two pendants about island bench 4Jun 23, 2017 1:41 pm If it was up to me i would use 3 pendants as 2 spotlights might not be wide enough to cover the whole length. Equally spaced would mean 750mm, 1500mm, and 2250mm. It also depends on your aesthetic - you might want them to be all closer to the middle than spread out? Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 I am trying to find lighting for kitchen, dining areas but looking online, I don’t know if there are specific details I should be looking at to make sure any lights I… 0 963 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6668 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 21123 |
