Browse Forums Lighting + Lighting Design Re: Adding dimmers after lights finished.... 2Aug 18, 2008 9:37 pm Yes. My builder gave me this tip. He was trying to save me money
Although he knew my dad is an electrician. Not sure how easy it would be for non-electrician, but it's just a matter of buying a special dimmer switch and replacing your normal switch with it. When I asked dad he just said to make sure the switch is going on the plaster not the architrave. Re: Adding dimmers after lights finished.... 3Aug 19, 2008 2:46 pm not sure.....we are having one in the Home Theatre and PD charged us $40. Happy at Home Re: Adding dimmers after lights finished.... 4Sep 01, 2008 12:26 pm Hi there bec,
To add in dimmers at a later date, is a very simple procedure. Even a first year apprentice is capable of doing this upgrade. In addition, even if it is in an architrave, the only problem you may face, is whether the cavity space is enough. Otherwise, it's no different. Hope this helps. Re: Adding dimmers after lights finished.... 5Sep 03, 2008 8:59 pm It's important to note that not all globes are able to be dimmed. Not that this is a problem, as you can usually change the globe to one that is able to be dimmed. Most "compact fluro" globes can't be dimmed due to the electronics inside them, however there are a few compact fluros now on the market that are dimmable. Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46961 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10913 |
