Browse Forums Lighting + Lighting Design Re: Can dimmers be retro fitted? 3May 03, 2017 8:40 pm Thanks.....we went with expensive plates so won't be changing those. I guess we'll just use lamps for low lighting... Re: Can dimmers be retro fitted? 5May 07, 2017 8:29 am You may also need to replace the lights if they are LED luminaires. They have devices called "drivers" and these can either be dimmable or non-dimmable. If the drivers are external you can just replace the driver, but if they are integrated into the luminaire then you have to replace the whole thing. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Can dimmers be retro fitted? 6May 20, 2017 10:05 am To update - I asked electrician and dimmers can be added....BUT, we would have to change the face plates of the switches to add the dimmer button - not going to happen as we have Saturn face plates which were a bit extra than standard... Re: Can dimmers be retro fitted? 7May 20, 2017 11:31 am lazandjohn To update - I asked electrician and dimmers can be added....BUT, we would have to change the face plates of the switches to add the dimmer button - not going to happen as we have Saturn face plates which were a bit extra than standard... That is just not true. There are all in one button and dimmers available that you can use on a one to one swap. They are expensive, but you would have to pay for rotary dimmers also, so the cost difference is minimal Cabac push button dimmer on eBay https://www.ebay.com.au/itm/122044428846 Clipsal push button dimmer on eBay https://www.ebay.com.au/itm/201920660455 Clipsal rotary dimmer on eBay https://www.ebay.com.au/itm/201923729562 These are the cheapest I could find. We are going with the Cabac ones and I bought them in a batch lots from Jamel Cables at a discount. Tell your electrician to do better research or get a better electrician. I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15284 2 10988 |
