Browse Forums Lighting + Lighting Design 1 May 25, 2016 5:14 pm Has anyone here used LED strip lighting under there overhead cabinets in the kitchen? Did you have a recess in the cabinet for the strip lighting or did you stick it direct to the bottom of the cabinet? Anyone with closeup pictures would be appreciated. Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: LED Strip Lighting For Kitchen Overheads 3May 25, 2016 9:59 pm Are you using the normal flexible strip? How big is the recess going to be? Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: LED Strip Lighting For Kitchen Overheads 4May 26, 2016 5:49 am I know of someone who used standard led strip,lifting but put a screwed a piece of stainless steel angle in front of it to hide it ... Looks awesome I'll find a pic Our Acreage Build ![]() ![]() ![]() viewtopic.php?f=31&t=82619 Re: LED Strip Lighting For Kitchen Overheads 5May 26, 2016 9:11 pm The LED light I'm using is with a profile and diffuser bought before the cabinets were made, supplied to the cabinet maker so they could make the rebate to the size of the profile supplied, which then the profile/led is fitted on site. Re: LED Strip Lighting For Kitchen Overheads 7Jun 12, 2016 10:52 pm This type of profile is the best, just need a channel routed out of the joinery and the LED profile fits right in. The LED ribbon tape fits inside the profile. The diffuser softens the light so you don't see the dots, and spread it out over the bench better. https://www.domuslighting.com.au/led-pr ... d3%2322048 Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED Strip Lighting For Kitchen Overheads 8Jun 13, 2016 10:58 am Thanks guys. We ended up gong with a chanel from CLA Lighting. http://www.clalighting.com.au/product/l ... ed-strips/ The Chan1 in the top of the image (which is the same as the Domus product) Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Struggling to find a chandelier with LED globe replaceable without any LED diver for my U-shaped staircase. Please share details if you bought similar to… 0 9615 0 8138 Make sure you have the required soil bearing capacity at the shallow founding depth and the strip footings are designed for the expected loads over (including the wind and… 1 12855 |
