Browse Forums Lighting + Lighting Design 1 Apr 07, 2016 10:46 am I'm an electrician and will be wiring my own new house soon. Just wanted to know if there are any other sparkys who have wired their own new house and what creative things they have done with lighting. Strip lighting in the bathroom or kitchen? Down lights? Wall lights? Outdoor deck lights? Sensors? The list is endless! What did you do to make your house stand out from the basic electrical plan? Re: Electrician wiring your own house. 2Apr 07, 2016 11:26 am Can't help you. I wired my own house but did the absolute minimum amount of electrical work.
I would rather spend my non working time doing other things. I installed pendant type lights in living areas because they are easier to reach to change the light globes. Re: Electrician wiring your own house. 4Apr 07, 2016 12:48 pm Mute88 In your working time, what sort of lighting ideas have you come across? Have any customers asked you to install something other than the standard pendant or downlight? I only work in commercial and industrial areas. Anything unusual is normally dreamed up by an interior designer. Re: Electrician wiring your own house. 5Apr 07, 2016 7:41 pm You should ask this guy "1960's Modernist Home" in this thread here...viewtopic.php?f=8&t=80131 Stewie Re: Electrician wiring your own house. 7Apr 09, 2016 6:59 pm You're welcome to look at my own home here viewtopic.php?f=53&t=82091 where I have used some creative lighting. Photos are not that great so if you want to see better photos of anything just leave a comment on that thread and I will post up a better photo. Some ideas that I used were: - recessed lighting track with adjustable spotlights - LED strip concealed under benches, cupboards and behind mirrors for a 'halo' effect - Pendants in certain areas - Low glare LED downlights (not the cheap-o opal diffused type you see everywhere) - 12V LED spotlights in the gardens on PE cell/timer - Curtain pelmets above windows with concealed LED strip lighting - Recessed LED wall wash profile with RGB LED strip and a touch screen controller to change the colour (in ensuite) Also ran dual Cat6 data outlets to each room, 4 behind the TV, back to a patch panel in the store room downstairs where the NBN hub is. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 0 1337 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20353 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39464 |
