Browse Forums Lighting + Lighting Design 1 Mar 13, 2016 6:50 pm HI Guys im after some advise here in our bathroom we have this weird setup (see photo) which has a halogen globe mounted in the centre - ideally i would like to replace this with something LED any thoughts on what or how?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Untitled by Adrian Miles Photography, on Flickr[/img] Re: Modify light fitting 2Mar 14, 2016 8:33 pm Posting to bump question for you. Im not much help as i dont even know if it can be done but could you take out the moulding that is below ceiling level, plaster over it and get a new light fitting ? Good luck and hopefully someone will help you a bit better than me lol Re: Modify light fitting 3Mar 15, 2016 12:00 pm I may not be reading the picture right, but I can't seem to see the halogen fitting. For some types of halogen fitting, there are drop-in replacement LED fittings. Re: Modify light fitting 4Mar 17, 2016 5:55 am Can you take a better photo of the actual luminaire? Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11711 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17380 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19992 |
