Browse Forums Lighting + Lighting Design 1 Mar 02, 2016 10:39 am Hi everyone, I've found some pendants on sale at Beacon that I'm thinking of getting for our kitchen island. They are 3 grouped in a cluster at different lengths that I will put at one end of bench. Only $208 atm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Originally I wanted these ones, but they are all individual lights that add up to over $600. So thought the above might be a comprise lol. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But I'm worried they might not be long enough?? We will have quite high ceilings at 3094mm, the total length of the pendants (the lowest one) is 1260mm. With a benchtop height of 900mm, that leaves around 930mm from the bench to the lowest light. Do you think that will work?? Or do they need to be down further? Looking forward to hearing your thoughts! Re: Do you think these pendants would work with our high cei 2Mar 02, 2016 11:32 am At that length it goes down to 1834 off the floor, and any lower than than you start running the risk of hitting your head on it if leaning over the bench, and also producing glare at eye-level. I don't know about the aesthetics though. Re: Do you think these pendants would work with our high cei 3Mar 03, 2016 9:31 pm I'd say that would be about optimum height Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39756 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2472 I am trying to find lighting for kitchen, dining areas but looking online, I don’t know if there are specific details I should be looking at to make sure any lights I… 0 397 |
