Browse Forums Lighting + Lighting Design 1 Dec 22, 2015 10:49 am Hi Our island bench is 3 metres long and 1.2 metres deep. What size pendants should we look for? Ceiling 2.7m. I like this but not sure if it will be too big or cast too wide of light. http://www.mattblatt.com.au/Pendants/Re ... x?p13618c2 Thanks Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Lighting for island bench 2Dec 22, 2015 4:09 pm If you are not using a pendent for dining, I would say go for these. I have 2 of them in 3.5 metre bench and thinking to replace with a bit bigger ones. Not the same, but we have got something like this: http://www.bunnings.com.au/verve-design ... p_p7071439 Could not find the ones I bought from them Re: Lighting for island bench 3Dec 22, 2015 4:11 pm Got it: http://www.bunnings.com.au/verve-design ... p_p7071437 this is the one I used. I want to go for a bit bigger ones. Re: Lighting for island bench 4Dec 22, 2015 4:40 pm Thanks for your reply, well at this stage we were thinking of a pendant over the dining table. I don't of course then want them too big or competing with each other. Might need to choose something smaller for the island? Is there a rule of thumb for size of pendants to islands etc. anyone? I guess it's a matter of what looks good. Hard to choose when kitchen not built.. Are we better waiting I wonder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Lighting for island bench 5Dec 22, 2015 4:41 pm Gaggy Got it: http://www.bunnings.com.au/verve-design ... p_p7071437 this is the one I used. I want to go for a bit bigger ones. Yeah I've seen ones along those lines. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Lighting for island bench 6Dec 22, 2015 4:45 pm Leksie5000 Thanks for your reply, well at this stage we were thinking of a pendant over the dining table. I don't of course then want them too big or competing with each other. Might need to choose something smaller for the island? Is there a rule of thumb for size of pendants to islands etc. anyone? I guess it's a matter of what looks good. Hard to choose when kitchen not built.. Are we better waiting I wonder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Difficult to say I would say. See a few display homes near your area and that will give you an idea. But I would not use too big for island if you are using one for dining. Having said that its a personal preference. Re: Lighting for island bench 7Dec 22, 2015 5:31 pm Gaggy Leksie5000 Thanks for your reply, well at this stage we were thinking of a pendant over the dining table. I don't of course then want them too big or competing with each other. Might need to choose something smaller for the island? Is there a rule of thumb for size of pendants to islands etc. anyone? I guess it's a matter of what looks good. Hard to choose when kitchen not built.. Are we better waiting I wonder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Difficult to say I would say. See a few display homes near your area and that will give you an idea. But I would not use too big for island if you are using one for dining. Having said that its a personal preference. Yeah not a bad idea about the display homes. Thanks. We got so bamboozled by them when we were thinking about going with one of the companies! But good for such ideas. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6584 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8812 |
