Browse Forums Lighting + Lighting Design 1 Nov 23, 2015 1:28 pm In my new apartment, in the master bedroom there is one single light fitting at the moment, with a rather odd chandelier. I want this gone and in its place, EITHER a really nice ceiling fan with light, OR a ceiling fan and another second light elsewhere on the ceiling. But is this possible? To have 2 separate fittings like this if only one currently exists? Re: One existing light fitting in ceiling...can two lights w 2Nov 23, 2015 2:18 pm If you have a light that's separate from the fan, then you need to have it a reasonable distance away so that you don't get flickering light as the fan blades cut in front of the light. In many cases that would be putting the light away from the centre of the room. The easiest solution is to replace the existing light with a remote controlled fan/light. This is a simple exercise, and will just use the same wiring. Depending on the ceiling construction, it may be possible to pull a cable across to another location, but it is a more difficult job. Then it's trickier still to run that through to another switch on the wall. Re: One existing light fitting in ceiling...can two lights w 3Nov 23, 2015 3:38 pm Cool, thank you so much! I think fan and light combo it is (the ceiling is vermiculite and we don't want to mess with it! lol) "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1515 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1148 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10018 |
