I remember several months ago seeing this on the news. But after several attempts to clarify this point with PD I have decided to open the question up to this forum. See if we can get a better answer. Than um aarh don't know will have to look into it and get back to you...... still waiting after asking I don't know how many times.
Downilight covers in roof
https://forum.homeone.com.au/viewtopic.php?t=5177
I think 1st July 2008 is mentioned as the date it came into effect.
Goodluck
Fibreglass batts on the other hand would be a much safer alternative as the batts are cut around the down light allowing about 50mm of space around the light fitting, also these batts dont get blown around inside the roof cavity. hope this helps.
1
This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite…
30/05/2023
traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade…
