Browse Forums Lighting + Lighting Design 1 Aug 08, 2015 9:46 pm Hi, We dont want to put a downlight in our toilets and would rather a globe option similar to the genie globes phillips do. Having trouble working out what the name of the fitting is called that the globes go into. Recessed E27 socket doesn't yield any suppliers. Any suggestions? We would like it to be recessed into the ceiling as much as possible. Re: Recessed light options 2Aug 18, 2015 2:41 am What you're describing IS a downlight Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Recessed light options 3Aug 18, 2015 10:44 am It sounds like you're after a downlight that takes E27 globes? Something like this? http://www.wellsaving.com/E27-100W-CFL- ... p-416.html You may find something like this in Australia by searching for E27 downlight. They may be hard to find these days though, as people would generally get an integrated LED kit instead, as it would be smaller. Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3210 I ran into trouble finding a lock that would fit my particular door, like your situation with your pivot door. I wanted a safe lock that couldn't be messed with easily. 4 25702 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 10156 |
