Browse Forums Lighting + Lighting Design 1 Jul 28, 2015 2:56 am I have recently run into a company call Klauf on Kickstarter. They make the exact under counter lights i want! The only problem is that i would like to hear from someone that owns some of the light from the first version. how bright are they?/how hot do they get?/ are they as high quality as they say they are? if any one owns these lights, can you please reply before the campaign ends? (40 days from now) Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8812 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8570 |
