Browse Forums Lighting + Lighting Design 1 Dec 01, 2014 1:47 pm I've been looking for virtually the same pair of timber pendant lights a well known lighting company is currently selling, but smaller (to use as a pair over a dining table). The dimensions for these are: Width / Diameter (mm) 540 Height (mm) 470 I know this is a long shot, but does anyone know anywhere that sells/makes similar lights to the attached picture? Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Timber pendant search 2Dec 01, 2014 3:24 pm pretty sure Beacon are th eonly place to get them. Have you asked them if they have a smaller size? Alternitively, search google for geometric light fittings + timber. WHile not exactly the same, theres quite a few nice ones. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Timber pendant search 4Dec 01, 2014 3:44 pm http://www.replicafurniture.com.au/repl ... vQod3XwANQ http://www.homeq.com.au/replica-pilke-6 ... vQodYqwAaA http://www.homeq.com.au/replica-pilke-6 ... vQodJmMAaQ Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6162 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3280 |
