hi All
Our 5 year old house has approx 37 halogen 50watt downlights.
The house also has 9ft ceilings and does get quite dark during the day.
What are my options of changing to LED downlights?
I have seen a couple of companies promoting LEDs installed for under $30 with the Govt incentives.
Doing some research on these compnaies I note they may use lower wattage (ie equivalent to 35w halogens) LEDs and there may be other charges if the sparky needs to climb into the roof space.
Should I be looking at converting to 240v LED's or retro-fitting LED's to the current 12v transformers.
I know from previous research that one of the only 12v downlights that will work with our current Aztec transformers are the BrightGreen DR700
Can you also recommend a supplier and/or electrican that will take care of the govt incentive paperwork
Any help much appreciated
Thanks
