Browse Forums Lighting + Lighting Design 1 Apr 27, 2014 7:16 pm We're only a matter of weeks away from getting the keys to our new house. Finalising our lighting selection and will be getting quotes from a couple of sparkies. We've incorporated a bit of 2-way (and even 3-way) switching for some circuits to suit traffic flows and such. My question is whether anyone has experience with the push button switches (standard and dimmable) and multi-way switching? (www.hpm.com.au/WhatsNew.aspx?pid=466). Does the little indicator go on/off regardless which switch is used (e.g. with a traditional switch, the light will be off when *both* switches are in either the on *or* off position). Related question, with the push button dimmers (www.hpm.com.au/Products.aspx?pid=470), when they're switched on do they default to "fully on"? (again, traditional dimmer mechanisms might be low, high, whatever when you flick the switch). Because we have a number of circuits and multi-way switching, in some locations we'll be fully occupying a 6-gang plate - hence the need to look at switch with integral dimmer. Re: Dimmable push-button switches and multi-way switching 5Apr 30, 2014 11:49 pm Thanks. Will check them out too. Have since determined which componentry in the HPM range will work with the dimmable LEDs we plan to install. At the end of the day, will leave it to the qualified sparky, but it's always useful to get familiar with the products. Re: Dimmable push-button switches and multi-way switching 6Apr 30, 2014 11:55 pm i picked out my styles by playing with them at homebase in subiaco, have you been there. i am the type of person who likes to touch feel hold first and at least i know what works with what lighting. i was also lucky enough to run into a clipsal rep while there though! Shelly switches require a paid subscription for full access to all features which is ridiulous given the lifespan of a home and if you were to sell it or buy a home with… 2 4553 I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1852 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4577 |
