Browse Forums Lighting + Lighting Design 1 Jan 29, 2014 1:24 am Hi, I have been trying to search for an Oval pendant light (see attached image) but surprisingly am having no luck. I am told (by the many light shops that I have visited in the past month) that it's an outdated shape/design. I am planning on putting one over my kitchen island, and would prefer one that has a metal shade (as opposed to fabric). Please let me know if you have come across one of these anywhere. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Oval Pendant Lighting 2Feb 04, 2014 6:39 pm Hi, I've seen a lot of lights in my lifetime, and would have to agree that this light does seem to be superseded. There might be a couple of Suppliers i know of selling this light, or similar, and could find out for you tomorrow. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: Oval Pendant Lighting 4Mar 16, 2014 4:52 pm Hi Again, It seems as though all suppliers I knew of have discontinued this light, and was unable to find something, but the below link is probably the closest looking fitting I could find for you. http://www.golights.com.au/pendant-ligh ... 5-lucretia I hope this helps. Thanks again Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: Oval Pendant Lighting 5Aug 22, 2014 10:45 am Good article here http://inside-living.com.au/using-light ... our-space/ on lighitng. Lead me to Satelight Design. I ended up getting a similar custom made light done (still being made) Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8813 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
