Browse Forums Lighting + Lighting Design Re: Led lights flickering (once an hour or so) - why? dimmer 2Aug 27, 2013 9:22 pm Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Led lights flickering (once an hour or so) - why? dimmer 6Aug 27, 2013 11:21 pm GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Led lights flickering (once an hour or so) - why? dimmer 8Aug 27, 2013 11:38 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Led lights flickering (once an hour or so) - why? dimmer 10Sep 19, 2013 9:58 pm Alright, so I have not had this fixed yet, but I have some updates. We have two sets of led lights on dimmers. Both sets has the same symptoms. Our bedrooms has ceiling fans (one with a dimmer, the rest without) and they are all experiencing humming (no flickering). The flickering and humming happens at the same time. I also started timing it, and it is happening on regular intervals, so it is something on a timer causing it. For example, I wrote down some times when the lights flickered one night (and I was doing other things, so it probably happened every 30min and I just missed it) 7.01 pm 9.01 pm 10.01 pm 10.31 pm 11.01 pm 11.31 pm As you can see, it is extremely consistent. I've googled this problem and got a few results, but not sure what to think exactly. Seems to be a lot of talk about ripple control, could that be the issue? Not a hundred percent clear on what that is or whether it would be this regular. When this happens, the lights will usually blink once quickly, and then maybe a couple of more times shortly after. The humming from fans however is constant and lasts maybe 30sec or so at a guess. None of the lights in fans or elsewhere around the house is flickering (they are all CFL). I assume the problem is probably happening everywhere, and other lights are not as sensitive? That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 18076 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23994 |
