Browse Forums Lighting + Lighting Design 1 Apr 13, 2013 5:28 pm Hi all, i'm new to lighting, have no idea and was hoping for some input in regards to it as I have to buy lights for my whole unit! I'm a big fan of the design of eglo's fres (only seen pictures though) http://www.eglolighting.com.au/products ... fres/85345 Do you think this would be suitable for a 5m x 5m area? Would the lighting be more diffused or directional? I was also looking at their pendant lighting but they all seem to be 1m! That would guarantee someone would hit their head on it. I have no idea in regards to this and any and all help would be appreciated. I was thinking something like this: http://www.eglolighting.com.au/products ... ants/92563 May be nice for the bedroom but again at 1m they're going to be too low, thanks in advance! Re: New to lighting 2Apr 13, 2013 10:13 pm The three light pendant would look lovely over a dining table or a short or square island. You don't have to have the single pendants hanging down 1 metre, just tell the electrician who fits them how far you want them to hang and he will adjust the length. Regards, Grumbles Re: New to lighting 3Apr 29, 2013 7:56 pm Condensed light source makes hard shadows, not recommend for reading coz you will feel so tire after short while. Having said that, it's good to bring out bling effects (ie, jewellery display, decorations, etc). For large area, 5m x 5m, I'd go for ceiling light plus some small ones on the wall if you are going to do wiring. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28813 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
