Browse Forums Lighting + Lighting Design 1 Mar 09, 2013 11:01 am Has anyone seen a touch lamp similar to this one for sale in Australia? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://www.mondiallighting.co.uk/dar-range-table-lamps-c-1_58_4/dar-hazel-touch-table-lamp-satin-chrome-crystal-with-shade-haz4046-p-31530/add_compare_products_id/31530 This version is lovely too. Slightly taller and takes a 60w bulb . more appealing on both counts, http://www.amazon.co.uk/Satin-Silver-Table-Pleated-Shade/dp/B002RFWCBG/ref=pd_sim_kh_1 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need a new touch lamps for our bedroom as mine has finally died( yay!) Which means I need to buy 2 the same. I prefer 3 stage touch lamps although not 100% set on this. I would prefer one that can take a 60W globe however( the one above can't) ATM the only alternatives I've considered that don't kill the budget are the following ones. http://www.ozlighting.com.au/Cafe-Lighting-White-Cambridge-Touch-Lamp-P9790.aspx%20%20With%20either%20the%20black%20or%20white%20shade. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OR http://www.wayfair.com.au/Oriel-Lighting-Zoe-Touch-Lamp-in-Antique-Brass-OL99454AB-ORI1167.html?refid=SHB49-ORI1167& Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OR http://micalighting.com.au/dome-touch-table-lamp.html Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or...... I guess I could buy this base and get a shade later but I'm not that taken by the plain white base. http://www.ozlighting.com.au/Oriel-Lancet-White-Touch-Lamp-Base-P11582.aspx Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Touch lamps- help & advice needed 2Mar 09, 2013 5:53 pm Thank you to those who PMed me with some suggestions. I've ended up ordering the 2nd one from a supplier in the UK. Now to wait for them to arrive. Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3075 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7012 |
