Browse Forums Lighting + Lighting Design 1 Nov 16, 2012 4:50 pm Does anyone know if you can buy lights that you can do yourself. Becaon lighting have some do it yourself batten fix lighting, but not a lot. In particular was looking at the up/down exterior lights. thanks. Re: Do it yourself batten fix 3Nov 17, 2012 1:20 am The problem you have is all DIY lighting clips onto a batten holder, or plugs into a power point, but excluding flood lights I have only ever seen over batten holder style. Basically if you need to use a tool with electricity you need to be a licensed electrician! 2 The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5172 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5151 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5970 |
