Browse Forums Lighting + Lighting Design 1 Nov 04, 2012 1:08 pm Hi, Looking for some advice or suggestions for improving lighting our U-shaped internal staircase. At the moment, we have what is basically a floodlight in our staircase on the middle landing (see pic). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The light (200W lamp) is facing upwards towards the wall (about 1.9m high on the 4m wall). It's okay but quite a narrow spread of light for such a powerful bulb. Unfortunately no opportunity for a ceiling based light. Anyone have suggestions for a better lamp to replace it with? Thanks Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4592 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2580 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 |
