How about the light points location? any suggestions? thanks.
Browse Forums Lighting + Lighting Design Re: Lighpoint location (plan)? 2Mar 27, 2008 3:06 pm Only thing I can think of is wall lights on either side of the garage. After 4 years - we're in! Re: Lighpoint location (plan)? 3Mar 27, 2008 3:32 pm A wonderful extra luxury are small wall-mounted lights next to the bed, positioned for reading. I love these in hotels, in home they'd be bliss. Of course to position these correctly you'd need to give careful thought to exactly where the beds will be. You may be able to position them in such a way so they could be either reading lights or study lights above a desk. Re: Lighpoint location (plan)? 4Mar 27, 2008 9:48 pm the downlights might be quite power hungry, if you want to save some $ on your bill, how about also add a normal light in family/living area, so that you can choose between the 2 for different occations? Re: Lighpoint location (plan)? 5Mar 27, 2008 10:18 pm Personally I don;t like halogens, and I think they don't like me either. When I was renting in Brisbane the kitchen/family area had about eight downlights and six would *always* blow out. Damn annoying and very difficult to replace the bulbs when you have high ceilings. I managed to push one right through into the roofspace - but then the whole house was a ******* brothers special.
They sold the place when we moved out for about $700,000. I recall the blurb said "rennovations done the right way". What a crock. The place was riddled with structural problems and cheap-ass shortcuts. Which is my long-winded way of saying "with that many lights make sure you get a good wiring job". Re: Lighpoint location (plan)? 6Mar 27, 2008 10:27 pm The spec for the downlight is "white fluoro downlights". i assumed this is a energy efficient GU downlight.
I have asked the forum before, should i opt for recessed (using regular cfl bulb) or the downlight (using halogen or alike buln). but i am still undecided of the efficientcy and also the overall installation and running cost. Re: Lighpoint location (plan)? 7Mar 27, 2008 10:41 pm You've really thought this through! we just completed our the other day.
I wouldn't be so keen on a fluro light in the kitchen. If you're standing at any of the work top, the light is behind you so wouldn't it be casting a shadow? I don't know what type of covers/holders you can get for fluros, but surely you can get a better choice from normal baten lights? Anthea Re: Lighpoint location (plan)? 8Mar 28, 2008 9:38 am I'm not sure of the function of the light on the outside of the bathroom but it looks like an odd place to put one?
Also are you going to have space beyond the alfresco to warrant the ones on the outside pillars - seeing as you can't see the actual light from in the house on in the alfresco? If it were my kitchen I would place one light - either battern or halogen over the sink, one over the bench facing the dining and one central one for access to the fridge/pantry. I know flouro's are brighter than incandecent bulbs, but the place we are renting at the moment has only one bulb in the middle of the kitchen, as well as the inbuilt little light in the rangehood and the light isn't great - infact we struggle to see into the pantry (just doors, not walk-in or anything particularly deep). Not sure about a flouro in the laundry either? Flouro's are generally better where the light will be turned on once, and remain on for a length of time. We have considered using flouro (round) lights in the bedrooms (I liked the light fitting) but were advised that if it was not going to be on for a long time then an incandescent/cfl (standard) light would be better. So maybe consider if you will have it on for a long time, cos they aren't great for flicking on and off all the time. I think the single light over the garage door looks great - really highlights the door, and unless people are going to be walking up the driveway, there isn't really much point to lights either side of the garage door - apart for more visual effect. Consider all the areas that you really need light - things like bathrooms, kitchens, etc need to be bright (not necessarily with one light, but when 2 or 3 are on... don't want to be blinded in the middle of the night!, and areas that only need to be low-light eg, passages. Just my opinion. Ray. Second Time 'Round Re: Lighpoint location (plan)? 9Mar 28, 2008 2:48 pm If anyone in the household does any kind of work in the garage, I would put in 4 instead of two shown on the ceiling, equally spaced.
Side lights in the garage walls is also a good idea. Greg Re: Lighpoint location (plan)? 10Mar 28, 2008 8:34 pm I'd review the fluros in the kitchen. too stark and harse for a food prep area.
Go for fluro downlight and put them on 2 switches, so you can choose how many you want on. Same for ther dining/lounge area. 3 or 4 switches to turn thatlot on. Go fro an oyster in the alfresco. Drop the spotlight. Put the garage and laundry on a sensor so as you walk in they come on as required and donlt get left on. And the rest will be fine. and corrent - do NOT put in HALOGEN lights. A thing of the past. Steve Lighting Plan 11May 03, 2008 12:48 pm OMG! This place will be lit up like a Christmas tree ... not a bad thing, but you may want to consider the following points:
- run some dimmers, - don't run more than 4 lights in one room off one switch (use as many extra switched as you can). - try the use of 2 way switches In the long term, these minor points will contribute to major savings on your power bill. Re: Lighpoint location (plan)? 12May 03, 2008 1:18 pm The only things I can think of is that I've allways found flouros in kitchens to look very dated - I'd prefer pendants over the bench and a downlight in the middle - but this is a purely personal taste issue. Also having the flouros in the middle of the garage is a problem if you ever plan on working on your car or even looking under the bonnet - the bonnet ends up blocking out the light and you cant see sqatt. I put my flouros closer to the back wall for this reason as you don't usually need light up near the entry anyway. But that probably not going to be a concern for most people ![]() Re: Lighpoint location (plan)? 13May 03, 2008 1:43 pm ![]() Also having the flouros in the middle of the garage is a problem if you ever plan on working on your car or even looking under the bonnet - the bonnet ends up blocking out the light and you cant see sqatt. I put my flouros closer to the back wall for this reason as you don't usually need light up near the entry anyway. But that probably not going to be a concern for most people ![]() You may be interested in https://forum.homeone.com.au/viewtopic.p ... age+lights mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Lighpoint location (plan)? 15May 04, 2008 10:30 am Thanks all,
We have asked the sparkie to delete the CFL. Instead we will put one donwlight over the sink, and two over the benchtop, and one infront of corner pantry. STILL undecided whether to put one in the middle of the kitchen? With the new arrangement do i need another lamp in the middle of the kitchen? Re: Lighpoint location (plan)? 16May 05, 2008 10:17 pm ![]() A wonderful extra luxury are small wall-mounted lights next to the bed, positioned for reading. I love these in hotels, in home they'd be bliss. Of course to position these correctly you'd need to give careful thought to exactly where the beds will be. You may be able to position them in such a way so they could be either reading lights or study lights above a desk. Hi Cabinfever, Thanks for the wonderful suggestion. I'm thinking of install a wall light for my bed-room, as there is always not enough space on my bed side tables. Just wondering where do you put the switches for the wall lights? On the wall? Regards, Aulyna Re: Lighpoint location (plan)? 17May 07, 2008 5:05 pm the best places for bed side wall lights is just to the side of the bed head.
the best way to measure it, is to lay in bed, and make sure you can reach the switch ... the electrician will do the rest. Good luck. You can use the limited info in the NCC steel supports for floor and roof loads.. What about Balconies with higher loads, structural masonry and hebel wall loads which… 15 5668 ![]() Thanks for info, yes met with Power Utility, Builder's Site Supervisor and Electrician on site and aligned on the mains connection. Seems like the builder and Electrician… 2 3799 |
