Browse Forums Lighting + Lighting Design Re: Brightgreen D900 installation confusion 22Jan 06, 2014 1:22 pm Hi, I would definitely not use a power board in the roof! its illegal, and not safe at all. I'm an electrician by trade, and can tell you from experience that it doesn't matter in the slightest if you hard wire the driver to the electrical cable. LED's are designed to last for many years, therefore won't require maintenance. Yes, there may be the odd faulty one, but it'll be covered under warranty, and the electrician can swap it over in no time. If you have any further questions, please don't hesitate to ask here. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8523 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5253 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6219 |
