Dimming LED Downlights: PWM (Pulse width modulation)?
"Triode for Alternating Current (TRIAC) dimmers have been the most common light controller installed in households and businesses for over 25 years. This method works well with incandescent and fluorescent lights and will work with LED lights but not to the same optimal performance. The main problem that occurs when LED lights are used with a TRIAC dimmer is a significant visible flicker
To get the best result of high brightness, long lamp life of 80,000 hours+ and consistent flicker free dimming from an LED light, it is highly recommended that it be used in conjunction with an LED specific dimmer. LED dimming drivers dim LED lights by reducing the forward current through Pulse Width Modulation (PWM) via a digital control."
I have a few questions for the experts:
1. Can anybody please recommend a good PWM style dimmer?
2. Has anybody seen any remote control or bluetooth PWM dimmers on the market?
3. Is a PWM dimmer installed as per a normal dimmer? I.e. a wall unit or is it installed off the LED driver/transformer?
Thanks,
Chris
That information could be a little old as most quality drivers will deal with a Triac dimmer no problems at all.
In actual fact most LED drivers take the TRIAC signal (AC) and covert it to DC and dim using PWM.
Push button dimmers have caused some grief but Clipsal just released one recently that is pretty awesome we were getting down to 1%.
Model is 31E2PUD not real cheap but one of the best out there for LED.
4
Thanks again for this information. If you do hear anything different, would be great to know >
20/01/2024
2
Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing…
