Browse Forums Lighting + Lighting Design 1 Jul 04, 2012 8:55 am Hi All, We are going through a volume building for our new double storey house and are just preparing for our electrical appointment. We've been given a lighting handout which details various fittings etc we can select. Unfortunately, the options/fittings are very limited so we were wondering if we put normal batten lights in on the ground floor of the double storey, could these be later changed over to pendents etc.... or would this have to be done during the build as access is required to the floor cavity? I believe downlight changeover is possible but not sure about pendents and other light fittings..... Re: Post handover lighting installation - ground floor..... 2Jul 04, 2012 9:55 am Depends on the weight of the fixtures. Basic pendants can be attached to the plaster, or they make a small hole in the ceiling to attach a hook to timber behind the plaster. The hole is then covered by the ceiling rose of the pendant. Heavyweight fixtures like chandeleirs need a noggin in the celing and this is a very difficult retrofit job in a lower story. We've got a 25kg light over the dining table, and this is attached to two ceiling noggins, and the suspension cable is additionally wrapped around a joist as a secondary measure. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13657 |
