Hi,
I'm still trying to decide between:
http://www.electricalproducts.com.au/exls230522w.html
And
http://www.electricalproducts.com.au/ar ... yster.html
For the latter I'd probably buy an LED globe and put it in, I noticed that on ebay there are hundreds of $5 globes.
In the other extreme there are $80 phillips LED globes.
Does anyone know if there are any LED's they have used that are E27?
Or is there any recommendations?
There seems to be a lot of info about LED in downlight form but not much about anything else
The other challenge with the light I'm choosing is the light needs to be diffused quite a bit...so they recommend a 75W globe normally, I assume a 12-15W LED.
EDIT: I found these ones:
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... ink:top:en <-- looks like a chinese import
http://www.ebay.com.au/itm/10W-LED-LAMP ... 416648efff <-- looks good but probably not bright enough
http://www.ebay.com.au/itm/10w-LED-glob ... 2316b28dbe <-- looks good but also not bright enough
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... ink:top:en <-- bright enough but expensive!
For $10 I can get CFL's like this:
http://www.ebay.com.au/itm/15-Watt-Comp ... 6d7796b4da
About 1/5 the price of an LED
