Browse Forums Lighting + Lighting Design 1 Jun 11, 2012 10:52 am Hi all, just wondering how easy it is after build, to change a light from a down light to pendant light? We've got down lights above our bench, as the pendant lights were an upgrade and too expensive for us at the time. If we decided later to put pendant lights in later, are they easy to switch over? Have never done this before. Thanks in advance, Ainslee Re: changing from down light to pendant light 2Jun 11, 2012 12:01 pm Hi ainslee, our electricians drilled holes for down lights where we were actually having pendants, luckily the pendant faceplates were bigger than the holes, so they were able to put an extra nogging in the ceiling and hang them, no problem. Re: changing from down light to pendant light 3Jun 13, 2012 8:57 pm Could you get batten's where you want the lights to go? That should be a lot cheaper than downlights... Re: changing from down light to pendant light 4Oct 02, 2012 9:49 pm Hi Ainslee, I'm new to this forum so you may have already come across this product that solves this exact problem you have posted check out http://www.nustylelighting.com.au if you are still needing to make the change then I believe you will be interested in the options available now on the market. Hope this helps How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11924 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5536 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 4241 |
